It's about time for an upgrade, and I'd appreciate all / any thoughts on the spec I've been eyeing up. The machine will be used for fairly advanced .net dev work, a spot of web design and a fair amount of gaming, as well as general 'office' use.
I already have a couple of HDDs and a Pioneer DVDRW to put in this new machine, as well as a posh soundcard, so those aren't needed. I'll basically consider everything up to about £2000 (the above is ~£1800) as this will be used for freelance work and I'll make the cost back fairly quickly.
One concern I have is the total lack of AM2 HSFs around at the moment. I'd ideally like a good Thermalright one, having had good experience with those in the past, but none seem to be available. Does anyone have any idea what is appearing and when on this front?
Thanks as always
arty
- NEC LCD20WGX2
- Logitech diNovo Media Desktop Laser keyboard and Mouse Set
- Silverstone Temjin TJ07 - Black
- OcUK GeForce 7900 GTX 512MB GDDR3 TV-Out/Dual DVI
- Asus M2N32-SLi-DLX nForce 590 SLi (Socket AM2) PCI-Express DDR2
- AMD Athlon 64 X2 Dual Core 4600+ 2.40GHz (Socket AM2) - Retail
- Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU
- OCZ Platinum PC2-6400 EL XTC 2048MB Kit, DDR2, 240 Pin, 800Mhz (4-5-4-15)
- Zalman VF900-CU Quiet Copper VGA
Thanks as always
arty
....no really
