I have to put together a high-spec PC for work (and some heavy graphics gaming use - DX10 included), and would like to get some advice and opinions from forum members. I don't want to be re-building this PC every 6-12 months, so want to try and get a good spec with some longevity.
I would like to (as far as possible, and recognising that there's never a good time to build/buy a PC!) put together a spec for a PC that fits, as much as I can, the following spec/guidelines.
Also, I'm trying to work out how much I can future-proof the PC, without paying through the nose for things like DDR3. What observations/suggestions can you make about this base spec;
Spec:
CPU - probably Intel Core2 Quad Q6600 SCLAR (based on price v overclockability) or should I be thinking about Penryn?
New High Speed MHz FSB Motherboard - SLI if at all poss (and maybe DDR3?) suggestions really appreciated here please!
Memory (is DDR3 really worth having) 2GB - suggestions please!
2-3 Samsung 500GB HD501LJ Spinpoint T (perhaps in RAID)
2 x 8800 GTX Ultra or similar or GT? (advice/suggestions please on this one)
PSU - Coolermaster M1000
Screen - Dell 30" LCD (a must-have)
Case - whatever has the space and good airflow.
Issues/Questsions:
CPU - Q6600 or wait a month or two for Penryn or jump in now? I can wait a short while before having to build this PC.
M'board - not sure if any of the new higher-speed FSB boards support SLI but would really like it - does this mean wait for ESkulltrail - anyone know when that might happen?
Disks - will RAID give me much of a performance benefit (I realise in some RAID configs I'll need to pay a lot of attention to backing up etc) or is it really just unnecessary complexity?
Cooling - Could I expect to overclock the Q6600 to 3-3.2GHz with cooling from an Arctic Pro 7 (or similar) or should I use something like the H20 combined h/sink and pump kit?
Memory - Will DDR3 make much real difference to real apps/games or will it only show mainly a difference in benchmarks etc?
Graphics - Will SLI (if its even available on the new higher speed FSB mobo's) make much difference when adding a 2nd 8800GTX or is it uneccessary expense and doesn't add much? Is there benefit in GT v GTX other than price and a few % less performance?
Overclocking - I'm new to overclocking so don't want to take this PC to the edge, just get a bit more out of it).
do you have any other observations???
Many thanks for all inputs.
Neil.
Spec:
Issues/Questsions:
Neil.
