I upgraded my rig a few months ago with an Epox 9NPa+ Ultra mobo and an X800XT. Looking at the voltages in the bios and in CPU-Z, they seem to be a little high for my Newcastle 3500+ 130nm which is rated at 1.5V:
1.58-1.6 CPU Voltage
2.72 DIMM Voltage (not sure if this is high or not for value corsair ram)
Im running a reserator 1 and getting 43C idle temperatures for the cpu.
Everything is running at stock and there doesnt seem to be an option to reduce voltages anywhere, should i be concerned about this or is it normal? And is there a solution?
Thank you
Alex
Thank you
Alex
