- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Ok guys,
Now I'm all solared and batteried up, I'm now looking at heating.
I know low temp heat pumps are pretty controversial at the moment, dubious in terms of ROI and very disruptive to both your house (rip the place apart for new radiators, insulation) and your lifestyle (plan your heat 24 hrs in advance!).
However these high temp ones are now being released in the UK, which are just straight swaps for your oil/gas boiler and look pretty compelling.
Has anyone got any experience/ thoughts on these? After oil has risen from a £230 bill to around £1000, I'm keen to free myself from that and love the idea of heating through solar/cheap electricity rates using batteries....
www.theecoexperts.co.uk
www.daikin.co.uk
![www.theecoexperts.co.uk](https://images.theecoexperts.co.uk/wp-content/uploads/2022/01/the-Daikin-Altherma-3-High-Temperature-heat-pump-in-a-house.png)
High Temperature Heat Pumps | Are They Worth It?
High temperature heat pumps can cut your bills and carbon emissions without you getting new insulation or radiators. Here’s how they do it.
![www.theecoexperts.co.uk](https://www.theecoexperts.co.uk/wp-content/themes/iris/dist/img/theecoexperts-favicon.png)
![www.daikin.co.uk](https://my.daikin.eu/content/dam/b2c/shared/images/DAIKIN%20ALTHERMA%203HHT_3_4_1A%20.jpg)
Daikin Altherma Air-to-water heat pumps
Yes to air-to-water heat pumps. Not only are they eco-friendly, they're also budget-friendly. Discover the Daikin air-to-water heat pumps.
![www.daikin.co.uk](https://www.daikin.co.uk/etc.clientlibs/b2c/clientlibs/b2c-theme/resources/icon-192x192.png)
