Presumably these are at idle? 59 degC is a bit hot if thats the case. i7 920 D0 idling at 35-38 degC at idle here @4Ghz. Try stressing the CPU and see what temperatures rise to.
Badly seated heastink or thermal paste?
More than likely, you should be using a pea sized blob of paste.
Or if it came pre-applied, then just re-mount it, and give it a small side to side wiggle/turn.
Ahh can't take this pin out.I am lost for words how bad this design is. Someone please tell me a way to get this last pin out, I am not chuck norris and neither do I want to break my motherboard.Those dam push-pins!!! the pc builders worst enemy![]()
