- 23 Jan 2013
I have a file server with an intel pentium g630t, with some temperature monitoring scripts. During a recent backup the cpu hit the 45°c Mark I set and the server shutdown, this has happened a couple of times now and it's starting to become a little annoying.
The server is built inside a Fractal Design Mini Array R2 and the CPU has the stock intel cooler fitted.
Am I being to conservative with my top temp or is my CPU running hotter than it should be?
I noticed also that webmin states CPU load to be at 2.26 during the last minute but apparently the percentage monitor says 49% idle which I thought was odd but not the point of this discussion.
