He's close to thermal throttling on the CPU anyway.
He has 3 intakes on the front pulling in air, I can't see how his air temps would be bad enough in the case for VRMs and other components to start overheating, I only have 2 intake on the front and they go through my AIO, 1 exhaust on rear and 1 exhaust on top. He has much better cooling than I do and his temps are terrible.
Well I had the stock fans on my case, two intakes. Yet when I swapped them for 2 new ones, my case temp drops 10C. Why? Because if they don't have the pressure to overcome the filter, they're not actually doing anything. CFM is basically seeing how fast the engine can spin the fan (they stick it in a tube with the air already moving). Pressure is how much resistance it can overcome, and the filter on the front of the case is going to be producing some relatively strong resistance.
If you start intaking through the radiator, especially on a chip that'll be throwing out a lot of heat, your internal temps are going to go much higher, and passively cooled items like VRMs are likely to really suffer.
So if you need sufficient airflow to remove that excess intake, you may as well set it up to be sucking that air in properly in the first place, and then venting it through the radiator, keeping everything cool.
