Have 2 of these cards sitting very close to each other in Crossfire on an Asus P5E3 Premium motherboard, and the temps seem scarily high to me. Haven't been doing anything much on the PC except installing programs in Windows (Vista 64bit), and one of the GPU's is at 76 degrees
- that's the one that shows as connected to the monitor and is the top card (not a lot of room underneath since the slots are very close). The others are at
49 degree's c
60
64
cpu temp 24 degrees, system 31 degree's, and 4 chassis fans currently running at about 1350rpm each (1 front intake, back exhast, 2 top intakes) in a Silverstone TJ-09 case. Though makes no difference to temps really lowering those down to 800rpm. Anyone else that has 3870 X2's in Crossfire what kind of temps do you get just idle in Windows? I'm thinking 76 can't be normal.
maybe it's possible to plug the DVI cable into the bottom graphics card that has more space inderneath for airflow, and see if that helps. Don't really want to have to downgrade to 1 card due to too much heat coming out, it's feeling abit like an oven at the back right now
- that's the one that shows as connected to the monitor and is the top card (not a lot of room underneath since the slots are very close). The others are at49 degree's c
60
64
i did that for my 3850 crossfire
