- 19 Jun 2014
Built a PC yesterday at about 10pm (GMT) went to bed, then went to work came back and thought right time to overclock CPU.
So I have my i7 4790k, Asus Maximus VII Ranger (Z97), 8 GB RAM 2133Mhz and a GTX 780Ti. H100i cooler
So my temps are fine when cpu is at idle - sub 30c, but as soon as it gets to about 80% load its at about 95c - 100c.
Im using Intel Extreme Tuning Utility to check, Temps, Voltages and Stress tests etc. I ve also got open CPUz and Open Hardware Monitor (just to make sure temps and they all say the same when at about 80% load CPU hits 95c to 100c.
Any help would be appreciated
Off to bed before work and then i will be back at about 2 - 3 pm (GMT)
Things to note :
This was an EZ Tuning overclock(Automatic overclock of CPU and DRAM on Asus Motherboard)
CPU Voltage is 1.27539063v
with no Dynamic CPU offset
Reference clock is 102.0071
CPU Multipliers 45x on all cores
Things to note :
