Dear All,
After one of the keen eyed members noticed my CPU temp was a bit high on a previous post, I have replaced the defective CPU fan with an Artic i30 which appears to be doing the job on the CPU against what was previously showing (using HWMonitor) down from 46C to mid 30's on idle).
On the advice on the same post, I've undertaken the task to overclock the CPU using the MB (Gigabyte) ET6 utility, gradually, I'm now up to 3.8, but I ran a Torture Test using Prime95 and whilst the CPU Core Temp's stayed fairly ok, with a Max of around 56C, the TMPIN0 and 1 registered a max of 107C and 115 respectively.
I've done a fair bit of reading on line and whilst some say it's probably a faulty reading/sensor, others are leading to it being an issue, is there any concise definition someone could share? I've read the excellent guide on here, which led me down the route, just worried about those readings.
I'm a little worried I may well be doing some damage.
Hardware is:
Intel Core i5 2500K
Gigabyte Technology Co., Ltd. Z68XP-UD3P (Socket 1155)
8.00GB Dual-Channel DDR3 @ 798MHz (11-11-11-28) - Which I will be u8grading in the coming weeks
1024MB NVIDIA GeForce GTX 560 Ti (Gigabyte)
Voltages are: CPU 1.080 and DRAM 1.500 according to ET6
Max for the utility is 4.10GHZ which I'm happy to be the max, however, just want to be sure I've not going to fry anything.
Cheers
Jjxs
Hardware is:
Intel Core i5 2500K
Cheers
Jjxs
i always seem to manage to nick a fan blade and crap mesel
