- 10 Aug 2016
- Saltburn By The Sea
Evening,
No idea how good Pre-Build systems are from Pc-Specialist. Regards model "Vortex ST-S" it seems that the airflow and cooling aren't that good at all.
MNeaing, One fan on the front and another fan on the back and the fan on the CPU block seems to be the same fan as the others.
This PC system is not mine but someone else. PC temps seem to be high from the GPU. Just the Other day it was over 80C but when doing MSFS2020 flight sim at 100% the temps are like 60C to 75C
Now, parts in the system are good
JUst that this system airflow and fans are just so badly done. With games that he might play the temps are going high as over 80C or 89C and he contacted support and said all good, all normal, nothing to worry about.... that's odd very very odd and not good.
I do not even think that the fans are even going max speeds
JUst that this system airflow and fans are just so badly done. With games that he might play the temps are going high as over 80C or 89C and he contacted support and said all good, all normal, nothing to worry about.... that's odd very very odd and not good. I do not even think that the fans are even going max speeds
