- 9 Feb 2006
- Bridgwater/Somerset
Hi
Just got OcUK H²OC Watercooling Bundle(http://www.overclockers.co.uk/showp...38&name=OcUK%20H%B2OC%20Watercooling%20Bundle) its cooling a q6600 running 3.2 gig @1.36v
The thing is the cores are running at about 57 degrees under load (F@H)
which is no better then my old Evo 120 with a sharkroon silent eagle 1000. The rad is mounted at the bottom with a sharkroon silent eagle 2000 blowing cool air on it from the bottom, room temp is 27 degrees, I have remounted the CPU block several times with no difference in temp. I have also made sure that I have connected the CPU block the right way along with it flowing the right way e.g. input used as input. any suggestions?
rest of spec is:
Coolmaster cm690
gigabyte p35-ds3p
8800gts (g80)
4gig g-skill pc6400 5-5-5-12
Ps i have http://www.overclockers.co.uk/showp...t=1041&name=XSPC RS240 120mm Radiator - Black comming but not sure that will make a big diffance.
rest of spec is:
Coolmaster cm690
gigabyte p35-ds3p
8800gts (g80)
