- 15 Sep 2010
Hi everybody, i have read through some of the forums and hope i can get some usefull advice.
I have a Compaq Presario cq60-420sa.
After some research i have found it has:
winstron 303c motherboard
phoenix bios
nvidia nforce mcp78s chipset
nvidia 8200m g graphics card
amd athlon dual-core ql65 processor
I want to change the setting on the graphics card as they are on the lowest setting according to what can be changed
gpu graphics clock 400Mhz
gpu memory clock 675Mhz
gpu processor clock 800Mhz
My problem is the temps when gaming(in deg c), at the present moment the readings are mcp51, gpu=51, cpu=54, all that is open is this forum.
when i play online i get all three up into the 80(usually 83) and this is with a cooling pad, without it they were 88. The laptop has been repaired under warrenty because the temps were around 95.
The temps are taken from nvidia system monitor but were the same with a couple of other programs aswell, and i cannot get the temps from the bios.
Is there a way to lower these temps or are they ok. i have heard artic silver mentioned and wonder if it is worth going down this route to see if it works.
any advice will be very helpfull
Regards
Chris
phoenix bios
Regards
Chris
