Hi all,
Spec: i7 6700K Skylake, Corsair H100 AIO cooler, 16gb Corsair DDR 4, MSI Nvidia 1070, Asus Maximus VIII Ranger mobo
I've had my PC built for a couple of years now and never bothered to OC it, although when I bought it I did read up on the CPU to see if it had scope for overclocking and had it on my radar, just never bothered to, until today.
I downloaded CPU-Z, SpeedFan, HWMonitor and Prime95 and after much reading on overclocking the 6700k decided to go with a simple multiplier bump from 40 to 42 aiming for 4200mhz with voltage set to 1.25. I ran Prime95 and everything seemed stable, no BSODs, and at this stage I was using SpeedFan looking at the CPU temp and under stress testing the CPU temp was reading around 65/70 max, so I thought all was well. I then aimed for 4.4ghz which at 1.25 caused a BSOD pretty quick, so I bumped the voltage up to 1.3 and tried again and Prime95 seemed stable - but at this point I switched to using HWMonitor and **** myself when I saw the temps.
Under 'Temperatures' in HWMonitor, 'Package' and 'Core #0' (through to 3) were all reading around 98-102c. I hit the stop button on Prime 95.
Intruiged, I reset the BIOS to factory defaults to wipe out the OC, booted up and ran Prime95 again with HWMonitor running - same thing again, core temps reading super high.
The 'CPUTIN' reading was around 55-60c whilst the core temps were ~100c, and SpeedFan's CPU temp reading is in sync with the CPUTIN.
What's also confusing is the core temps are quite happily sitting around 34c (often see this around 28c or less on cooler days) when idle, but within a second of starting the stress test they immediatly spike to ~100c - it's like they don't even need time to reach that temp. As soon as the test stops, they immediately fall back to reasonable temps.
For what it's worth - before all this OC'in lark I've had zero issues with the PC and stability, playing BF4/BF1/BF5 for hours on end in a fairly hot study due to the weather and never had any crashes or freezing up.
Can anybody explain what's going on?
HWMonitor / CPU-Z screenshots
The ~100c temps are during Prime95 execution, Small FFTs test)
After stopping Prime95:
Thanks for reading!
Thanks for reading!
