High Vcore Low Temps
21 Dec 2008
UK
High Vcore Low Temps.......is it okay to have your Vcore at like 1.4-1.5v if you temps are low?
Thanks for all replies.
A lot of people say that 45nm chips will degrade and the frequency will go down if you put more than 1.4/1.45V through them.
If I had a 45nm chip, I wouldn't be happy putting more than about 1.4V through it.
i get 35*c on idle...46*c at load....my overclock is not 24/7 stable as it fails on prime95 but i can use pc to play games etc if i can play the games for 1+ hours not sure yet... was thinking maybe i could increase Vcore a bit to make overclock more stable...i am at 1.4v at the mo but 1.375 in CPU-Z
