higher memory speed.
25 Nov 2007
London
i checked the forums a bit didnt find answer..
general question about, my current ram voltage is 1.8, 800mhz ram.. the question is when overclocking the CPU, do u have to keep ram at 800 or below, (increments are not small enough..) or can i increase voltage to 2 and run it at 850-900 or so.. ?
depending on your RAM, it is possible to have it go over 800MHz, as RAM can be overclocked as well just like a CPU. just watch the voltages and check for stability
