highest mhz ram?.
10 Feb 2011
Hi just curious what is the highest MHz ram you can buy?. I have just bought Vengeance LPX 16GB (2x8GB) DDR4 PC4-29200C18 3600MHz Dual Channel Kit - Black with my new system and wounded if there are higher?.
There is higher. Corsair do a 4800mhz dominator platinum range, but at that point you are talking very minimal gains and extremely expensive. Plus a lot can depend on memory controller quality to even get those speeds stable.
I run mine at 4150mhz and i think that is plenty quick enough :p
