Xplo said:Yeah thats another point how much life will be sucked out my athlon, will it be ok at 1.85v for atleast 2 years?
Havana_UK said:I beg to differ with chopchop.
This question can't be answered, but if the answer truly was none at all, AMD would have supplied these chips running at higher clock speeds with higher voltages.
Chances are that you'll be fine, however you'll be running the CPU out of spec (quite a long way out of spec), so it could at worst case fail instantly, but then it could easily last for 5 more years.
Hav
