** HighPoint RocketRaid Controller cards ** In Stock NOW!
20 Jul 2009
The bleak North East arm pit of Britain
Today at OcUK we have a new range of controller cards from HighPoint including the fantastic RocketRaid 640.
RocketRAID 2300 SATA 3Gb/s Raid Controller Card - PCI-E @ £114.98 inc VAT
- PCI-Express x1
- 2 eSATA & 2 SATA Devices
- 4 x SATA
- RAID Level RAID 0,1,5,10 JBOD
- Form Factor Low Profile
- Online capacity expansion (OCE) and Online RAID level migration (ORLM)
- RAID Array Roaming
- Unplug/Remove RAID array
- Hot key (ctrl-h) boot-up RAID manager via BIOS
- Firmware update while running the Operating System
- Verify RAID Array for Bad Sectors and Parity Check
- Task Scheduler
- Automatic RAID rebuild
- Automatic drive (insert / removal) detection
- Hot Spare Disk
- Staggered Drive Spinup
- Rebuild Priority (Low - Highest)
- Spin Down Idle Mode
- Hot Swap and Hot plug
- Bad sector repair and remapping to reduce dropped drives
- Multiple RAID array
Multiple Logical Drive
64bit LBA support greater than 2TB per volume
Only £114.98 inc VAT.
ORDER NOW
RocketRAID 1740
SATA 3Gb/s Raid Controller Card - PCI @ £105.98 inc VAT
- PCI
- 4 SATA Devices
- 4 SATA
- Task Scheduler
- Hot Spare Disk
- Multiple Logical Drive
- 64bit LBA support greater than 2TB per volume
Only £105.98 inc VAT.
ORDER NOW
RocketRAID 1720
SATA 3Gb/s Raid Controller Card - PCI @ £64.99 inc VAT
- PCI
- 2 SATA Devices
- 2 SATA
- Task Scheduler
- Hot Spare Disk
Only £64.99 inc VAT.
ORDER NOW
RocketRAID 640 SATA 6Gb/s Raid Controller Card - PCI-E @ £134.99 inc VAT
- PCI-Express 2.0: x4
- SATA 6Gb/s Controller
- 4 SATA Devices
- RAID: 0,1,5,10, JBOD
- Form Factor: Low Profile
- Task Scheduler
- Hot Spare Disk
- 64bit LBA support greater than 2TB per volume"
Only £134.99 inc VAT.
ORDER NOW
RocketRAID 622 SATA 6Gb/s Raid Controller Card - PCI-E @ £41.99 inc VAT
- PCI-Express 2.0 x1
- 2 eSATA Devices
- RAID 0,1,5,10, JBOD
- Task Scheduler
- Hot Spare Disk
Only £41.99 inc VAT.
ORDER NOW
RocketRAID 620 SATA 6Gb/s Raid Controller Card - PCI-E @ £54.98 inc VAT
- 2 SATA Devices
- 2 SATA PORT
- Serial ATA III (6.0Gbps) compliant, with speed negotiation Serial ATA II (3Gbps) and Serial ATA I (1.5Gbps)
- 600MB/s per SATA port
- Industry Standard AHCI Compliant
- Hot-plug capability
- Supports Native Command Queuing (NCQ)
- Out-of-the-Box Ready for Windows, Linux and Mac OS X 10.6 and above (Check AHCI detail OS support list)
- Compatible with SATA (III, II, I) Hard Drives, SSD, etc
- Support up to 2TB Hard Drives
- Power Efficient – Going Green Saves Green
- RoHS compliant
Only £54.98 inc VAT.
ORDER NOW
So the 1720 supports RAID 5 yet has only two ports. How does that work? Will it do the RAID duties for drives plugged into the motherboard?
