Hiper 525 PSU - On the edge ??
Permabanned
10 Sep 2005
Hi all.
Like the topic says, I've got a Hiper 525 in my rig. I've just upgraded a ton of kit - it all still seems fine, and haven't had any power issues, but am I pushing my luck?? Especially with such a load of expensive kit.
PC at present :
Asus A8N-SLi
AMD X2 4800 w/Zalman 7000Cu
2GB (2x1GB) DDR400
ATi X1900XT-X w/Zalman VF900Cu
LG DVD R/RW/RAM 16x
LG DVD R/RW/RAM 16x Lightscribe
Akasa 5.25" Fan controller
2xAkasa Amber 120mm's
Samsung Spinpoint 250GB SATA2
Maxtor PATA 200GB
Maxtor PATA 300GB
I've just got an X-Fi Fatal1ty from OcUK (arrived this morning), so will be chucking that in there tonight.
So what do we think - is this PSU maxed ?? Would you change it, or stick with it ?? Cheers.
Cheers, that's reassured me a little.
I've spotted a fair bit of Hiper bashing on these forums, but have never had problems with the 525 - fan is on auto and always stays low too. Was just concerned after seeing how much power the X1900XT-X can drain - most I've had in before was a 7800GT.
