Hiper Type R - Weird Problem
12 Nov 2005
Doncaster, South Yorks
Just got one of these for a friend and an Antec case only to find that the modular cables arnt long enough.
Anyone got any ideas where I can get some longer ones or some extensions from??
Cheers
Az
You cannot get longer ones unfortunately. This is a well known problem with this PSU.
Akasa Paxpower have good long cables if you decide to return it. I would also expect Antec PSUs to have adequate cable length for their own cases.
You can buy the 24 pin extension cables (to mobo), the 4 pin, 8 pin and the graphics extension leads.... Molex extensions and SATA power extensions are available everywhere.
Seek and ye shall find.
Sam C
Yeah, the cables are pretty short on the Hiper. They barely reach all the components in my Wavemaster. It's a really good PSU though. And it doesn't make a sound :)
Why not use the Modular cables to extend the cables which are short lol thats what i do with my Hiper in my Thermaltake Armour Case and thats one big case lol.
Thats what I do with my Ultra x connect psu, although its usually plenty long enough for my stacker, but theres one cable that just doesnt reach.
Try it before you return.
