Hiper vs Hiper
9 Nov 2006
Hiper HPU-4K580-MK Type R 580W
vs
Hiper HPU-4M580 Type R 580W
one is £64, the other is £52.
it seems like the performance is about the same, but what would you choose and what's the different? is the Hiper HPU-4K580-MK that neat?
i am on a low budget atm, so £12 is quite a big different for me XD
or Enermax Noisetaker 535W EG565AX-VE(W), OCZ ModStream 520w, both cost £64 as well.
Neither of the Hipers. They will go bang. There have been quite a few failures lately, mine included after over a year of use. I was unlucky enough for it to take out my motherboard as well.
PSU's are one area you should not skimp on. Out of the other two i would go for the Enermax. If you are on a tight budget then you really should shop around a bit.
vs
The Corsair HX520 is rated well and within the same price range.
