HIS 6870 Fan 1GB GDDR5 PCI-E
29 Dec 2010
Hey,
does anyone know if a HIS 6870 Fan 1GB GDDR5 PCI-E supports 3 monitors 2 dvi ones and a monitor using hdmi?
Thank you in advance
Very much
Dan
If you're referring to Eyefinity - "ATI Eyefinity technology requires one panel with a DisplayPort connector to enable the third display. DisplayPort to DVI dongle is required for panel with DVI connector "
im using 2 dvi monitors at the moment just wondered if i can use a 3rd one in the hdmi port?
or would i need that adapter?
thanks
As stated by Griff, the 3rd monitor needs to be from the Displayport. So you will need an active adapter like the one I linked to earlier. A normal passive one will not work.
