HIS 7950 Boost Voltage
13 Dec 2012
I'm puzzled!!!!
Just flashed my 7950 boost back to the original bios but the voltage is showing 1.169 instead of 1.25.
Any ideas why? :confused:
I reinstalled the drivers but no difference.
I'm puzzled!!!!
Uninstall drivers and overclocking apps (afterburner/trixxx) etc before you do the flash. Otherwise software can pick up the old voltage.
Just tried but no difference. What is strange is when I move the bios switch to the second position it's exactly the same voltage.
the voltage doesn't allways sit at 1.25 iirc, have you tried overclocking it a touch to see if it jumps up?
Tried but still stays at the same voltage.
I'm very confused.
what are you using to check the voltages?
can you try a different program?
and what are you using to ramp it up 100% usage? i'd try furmark or valley as they push the limits a bit more than some other programs.
