- 17 Apr 2010
I am trying to undervolt my card for day-day usage / light to moderate gaming, as I run a CF setup I have more than enough power, heat and fan noise is what I am trying to control
I have noticed that even if I lower the core voltage (mV) in afterburner from the default 1.125 right down to .950 (and counting), both cards still work - great you would think, but there's a snag.
I keep seeing voltage spiking to 1.250 in AB when monitoring, I assume this is the "Boost" part of the BIOS kicking in and assuming a default vcore rate, irrespective of what I have set (can't think what else it could be), I have tried locking the voltage in afterburner, and lowering / raising the clock speed, but it ignores this.
Is there a way to override this as it's both unnecessary for me, and OTT in terms of voltage (I can hit 1350 on the core using 1.137 mV).
Does anyone have a none boost edition BIOS I could test out? Can't find one on techpowerup.
Thanks,
Chris.
Thanks,
Chris.
sorry it couldn't help. I run 2xDP and 1xDVI so I haven't tried the hdmi port, but its useful info to others, I'm sure there must be a non boost version banging around somewhere.
