HIS ATI Radeon HD 4670 Fan Speed?
Not sure if it works on the HIS (due to using their own coolers, unless its not one of their ICEQ ones), but if you go into the CCC (Catalyst Control Center), and into the ATi Overdrive, if you click on the key to unlock it, you can then change the fan speed with the slider at the bottom, thats if your using either the 8.11 or latest 8.12 drivers however, as ATi have not long added that feature. :)
EDIT: It would stay at the speed you set to, so if you were going to start playing a game, then you would probably have to turn it up so it doesn't get to hot/overheat (as the fan wouldn't pick up to compensate).
Thanks for the information. Oh well mine doesnt seem to have that feacture and its 8.12. Will hopefully be getting a ikea cupboard to put in so keep the noise down.
