Getting home and unwrapping the new card (HIS ATI Radeon X1950 Pro ICEQ3 Turbo 512MB) I was very excited, I'd sorted out the driver removal the day before and got this all in and setup within an hour very pleased I seldom have problems with new computer hardware anymore which is great.
I boot up FEAR and stick everything on full, something my x1600 wouldn't even dream of handling, I get in game and WOW... it's running smooth as glass.
Sadly, 5 minutes into playing the screen just shuts off, black - the sound is looping in the background and the only way to fix it is to reboot.
I try again, same thing, so maybe it's FEAR I thought? no, I try everything from Ravenshield, Vegas, Oblivion even the ATI Benchmark utility - they all crash out like clockwork after sustained play. Whats funny is that in windows, it's fine! only 3D applications.
So I pull it out and put the old card back in, it's slow but stable. I put the new card in another machine and boom, does it again black screen after around 5-10 minutes. I put it back into the main machine and monitor the temps, it crashes anywhere from 48 degrees to 60 - these temps don't seem particularly high at all.
+ Tried the Omega Drivers, the CD Drivers and the updated HIS Drivers.
+ Ensured the power cable is in and that the 650Watt PSU is sufficent
+ Removed the old drivers properly
+ Ensured that cooling is sufficient even bumped the GPU fan along with all 6 of the case fans up.
I'm clueless.. must be something else on the new GFX card that is faulty, It's waiting in a box to be RMA'd on Monday, the only thing I've had go wrong from OC.co.uk so hopefully they will be able to replace it.
I hope they do and that the new one works because for that short time seeing it run FEAR.... wow.. fantastic performance!
A quick google indicates that this may be a common issue, wondered if it had effected anybody here?
