HIS Iceq 6950 and eyefinity DVI Cables????
Permabanned
6 Sep 2011
never had dvi cables before and this is really confusing me. jus got 3 monitors... Benq G2420HDBL...
need to get 3 dvi cables... but the GPU has ...
1x Single Link DVI-D
1x Dual Link DVI-I
1x HDMI
2x Mini DP....
Ive ordered the XFX mini DP to Single Link DVI...
http://www.overclockers.co.uk/showproduct.php?prodid=CB-000-XF
but according to this image
http://johnandlileth.com/Portals/3/Blog/dvi_connector_types.gif
DVI-SL has a few more pins...
im sorry im sounding really dumb... i need 3 dvi cables... which ones do i need??
The monitors have a DVI-D connection so you need 3 single link DVI-D cables.
1 cable will connect to the DVI-D on the graphics card.
1 cable will connect to the DVI-I on the graphics card.
1 cable will connect to the DVI-D from your DisplayPort adapter.
You can use Dual Link DVI-D cables but you won't see any benefit from them.
You definately don't want DVI-I cables as they won't fit in the DVI-D connector on the monitors.
1 cable will connect to the DVI-D from your DisplatPort adapter.
but this is what is confusing me... the adapter i have bought.. and the single link port has more pins then this http://www.datapro.net/images/1141.jpg
but aparently there both dvi-d single link????
The connector has more pins than the cable but for a single link connector some of them aren't connected to anything.
Only enough pins in the connector are wired up to provide single link operation.
+1
Looking at the image, the XFX adapter has all the pins for a dual-link DVI-D connection, but is only wired up to drive a single-link connection.
This means you can plug in either a single-link or dual-link DVI-D cable into the adapter and it will work fine - though be limited to single-link bandwidth (which determines the maximum resolution/refresh rate), but this is plenty for a 1080p @60Hz monitor like the BenQ.
If the monitors didn't come with DVI cables, then three of these would be the ones I would go for.
