- 31 May 2006
- Swansea
Hi
Yesterday I got my x1800XT but I am having problems with it. If I try and play UT2004 it will play for up to 15 mins fine but then the whole PC will freeze. Also if I try to play video files in windows media player the whole PC freezes. On both occations I have to do a hard reset - not even num lock works on the keyboard anymore. So far it seems to work with other games ok but I have not had much time to test them. Also 3DMark 05 ran without crashing too.
I have tried the 6.4 (on the supplied disk) and 6.5 drivers. I have tried it without installing CCC. Whatever I do I seem to have the same problems. It is running on a Tagan 530W PSU (also bought at the same time).
Any ideas what I can do?
Is it the card or is it driver related?
Thanks a lot
Thanks a lot
