- 29 Jul 2006
- Bristol
Hi all.
Yesterday I ordered a HIS X1900XT and a HIS X1900 Master card. I received them this afternoon and installed them into my P5W DH. I installed the catalyst 6.7 drivers and enabled Crossfire, all was going well until I started 3DMark2001.
Upon starting the benchmark I noticed that the screen was shaking from side to side. Thinking that it must be a driver problem I tried 3DMark03, the same thing happened. After a few more tests I realised that in any 3D app the screen would shake sideways.
So I uninstalled the 6.7s and installed the 6.5s, same thing happened. I swapped the crossfire cable with the one from my X1800XT crossfire setup it was replacing and I knew to be ok as I was using it 30mins before, still had the shaking.
Next I tried plugging the montior directly into the DVI port on the master card, success, no more shaking. Back into the crossfire cable and the shaking starts again (I always turn the PC off when messing around with cables).
I then disconnected the crossfire cable fromt he slave card and just ran the monitor from the crossfire cable connected to the crossfire port on the MC, and the shaking remained.
So, does anyone have any suggestions as to a solution, or do I just have a busted crossfire port and I need to RMA the card?
Thanks.
Edit, Sorry, forgot to post my system specs:
Conroe E6700 at 3.6GHz
Asus P5W DH at 360fsb
2x1GB G.Skill 6400NR running at 900MHz
Fortron 700W Epsilon PSU
Coolermaster stacker with crossflow fan
Coolermaster Aquagate with an extra Thermaltake 120mm rad
3x Hitachi SATAII 80GB HDD in RAID0 on the onboard Intel controller
Onboard sound
NEC DL DVDRW
Samsung 215TW 21" TFT connected via DVI
Thanks.
Onboard sound
NEC DL DVDRW
