Lads,
thinking about buying a slave X1900 to add to my HIS Master card, but have an outstanding query....It'll be going into an ASUS P5W..
If I went ahead with a "normal" HIS X1900XT, is it possible to overclock both cards to XTX speeds (I already run the Master version at XTX level).
Or, do the relative XT+XTX speeds go out the window when you're running a Crossfire setup and both cards run at the speed of the Master..
Only bought the HIS recently, and while impressed by the raw speed of it compared to my old 7800GTX, I feel it could use a little help at 1920x1200 with some of the latest games when all effects are on....Call of Juarez etc..
Does anybody here have a similar setup and ran into some issues that I wouldn't be aware of ?
Cheers
Cheers
) and the Master is the ASUS model......thing is, in CCC after 'unlocking' the sliders are inaccessible, showing 621 for core (at both top and bottom) and (I think, from memory) 721 for RAM - no possibility to adjust
