HIS X1950Pro (warning)
20 Oct 2002
HIS X1950Pro AGP (warning)
just a little note. if your going to buy one of these make sure your power supply has a 6pin pcie power connector or pick one up there is none in the box.
c0w
Aye, there was no adapter in the box when I got my X1900XT last year. It's kind of frustrating to sign for something and open the box only to find that you can't use it, even though the writing on the box says the part is included.
Not sure if this is the case for HIS as I haven't used them, but it happened with my Connect3D.
marc2003 said:
surely if you live in a town, there must be an overpriced electronics emporium you can buy one from? :p
The day I got my X1900XT I rang around all over Preston to find one because I didn't want to pay for shipping on such a pointless item, but absolutely nowhere had any (and we also have a very good wholesale/warehouse place here that sells everything.)
In the end a friendly bloke from these forums posted one to me for nothing.
Yep, very frustrating to open the box and not be able to install your new card for (in my case) 5 days whilst I wait for a cheap tacky one from ebay. REALLY frustrating that OCUK do not tell you this and haven't got the relevant cable in stock :rolleyes:
...but it's well worth the wait! Click the URL link on my sig for how I regard the HIS pro. :p
Got mine this morning..... missing a whole load of cables and the Xfire dongle (have emailed to get them sent), but my Etasis ET850 has 4xPCI-E conectors, so no worries.
What's happening with the new PCI-E power standard? CES-07 showed a few PSUs with *8-pin* PCI Express 2.0 power connectors.....
AnandTech said:
Enermax: Power and Case Products
Enermax is releasing an update to their Galaxy product line that features 850W and 1000W power supplies. These power supplies feature the new 8-pin PCI Express 2.0 cable design and will allow the use of two R600 cards. The power supplies feature five dedicated 12V rails with two dedicated to CPU operation and three dedicated to GPU, systems, and storage drives with 17A on each rail. The power supplies are designed with an 80~85% power efficiency from 20% to 100% load along with 6A on the +5Vsb to fully support 2007 Intel requirements and multiple USB devices. The units are designed to operate at full power on a 24/7 basis at up to 50c. Pricing for the 1000W unit is expected to be around $350 with availability shortly.
Also due for release shortly is an update to the Infinity series that will feature 650W and 720W units with full support for current SLI or CrossFire systems along with support for the new 8-pin PCI Express 2.0 standard. Both units are designed for 24/7 operation at up to 40c with an 82~85% power efficiency rating at 20~100% load. The units also feature the CoolGuard option that enables the system fans to run for up to 10 seconds after shutdown to help cool your system down.
*Sigh*
Why oh why did i not see this before checking out on Sunday. Anyone got a 4-6 PCI-E adaptor they want to sell to me. Got my X1950 Pro today,just opened it all up and no adaptor. OC are OOS on the link below with no eta. I won't be able to get to town till the weekend and i want to use it ASAP! :(
