Doubt there is much you can do, if it is as Kei said. It's a common problem for sound cards, that can vary in it's severity. Some models or brands of graphics cards, or other components may be more likely to cause it than others. It's the luck of the draw sadly. You may put the same sound card in another system, and it may work with no EMI issues at all.
