Hi, I have an Amd 3000+ 64 at a 38% oc.. on 1.450v. - At 2.5ghz
(Stock is 1.8ghz)
Well, jsut ran S&M to see how much the heat has affected my cooling... im at 50 degrees max! - Under load..
This is pretty worrying, imagine if I had the stock heatsink/fan. I also have a YS-TECH fan over the heatpipes.
I was about to do a volt mod on my motherboard in chance of increasing my overclock, the volt mod will make it 1.55v, is it worth it?
What temps will I be looking at?
Thanks in advance!
(Stock is 1.8ghz)
Thanks in advance!
