I'm currently playing Overwatch which most people will tell you is super optimized and can be run on a potato so I don't think it's the game but I'm having an issue where I will go from 120fps buttery smooth without a single drop to constantly yo-yoing up and down between 110 - 120fps, it's not normal frame drops though, it's more like micro freezing so the game constantly hitches and it's unplayable, it's like in Dark Souls III when the game pauses for a split second when it autosaves, but constantly. This issue can occur after 5 minutes or 2 hours, it's very random.
The problem I'm having is my PC isn't giving me a single hint as to why:
CPU and GPU loads at around 60%
CPU and GPU temps at around 60 - 70c
Clocks are stable
Event viewer is clear apart from one error I'll list below
I've tried:
Format
New thermal paste/clean out
Min/Max settings
Stock/overclocked
Reflashing BIOS
I mean it feels like some sort of hardware failure but my PC isn't suggesting such a thing, but what else could cause constant hitching out of nowhere? You'd think it would always run badly, not absolutely perfect for awhile and then all of sudden go to hell.
Specs:
3570k @ 4.4GHz
GTX 970
8GB DDR3
750w Corsair
SSD
Windows 10
365.10
Any help would be great because I'm completely stumped.
The Error:
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
{22279AF5-03AE-4CAF-989D-2530918B2F1C}
and APPID
{0773CCD6-59A2-4D26-B235-19247767E645}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
I have no idea what it is or if it's related, I tried to Google it but it's all very confusing.
Clocks are stable
I've tried:
Format
Min/Max settings
Stock/overclocked
Reflashing BIOS
Specs:
3570k @ 4.4GHz
GTX 970
8GB DDR3
750w Corsair
SSD
Windows 10
365.10
The Error:
and APPID
