Hitman Blood money demo - annoyances
1 Dec 2005
Stoke on Trent
1. Cant save a game part way through a level. if i quit i have to start the level again as it seems to delete the save games :mad:
2. It keeps forgetting my key assignments :mad:
Im pklaying on the easiest settings which is meant to allow unlimited saves.
The save system works quite well, makes you play through a level from start to finish, and will make the game last a little longer for you also. in my opinion anyway.
As for the controls, they're pretty simple, the 3 keys you really need are displayed anyway in the top corner, and the only other ones you need are movement and inventory.
