Hitman Demo
18 Jun 2004
Darlington//Sheffield
Im trying to play the hitman blood money demo on my 360 but when i lauch it it says it does not support PAL-50 and tells me to cahnge it to PAL-60
In the display settings i can't find an option to change it to PAL-60, its set at 1080i through component at the minute.
anyone got any ideas ?
Flick the switch on the component cable to SD, go back into the display settings and change it to PAL60. Then turn the 360 off and flick the switch back to HD.
In theory that should work, but I know Hitman was a pain for doing this.
AFAIK
PAL options only show for normal TV, not component/HD. So you need to switch to composite, change the option to PAL whatever you need and then switch back up to HD and it should work.
played the demo and it seems like quite a good game,
ive not played hitman since hitman 2 which i loved, is this worth picking up ?
