Hi all, Ive over clocked my e4300 to 2.9Ghz Using 320fsb 9 multi and stock volts. It is orthos stable but hits a wopping 70 degrees !!!! :O Im using a scythe infinity cooler and ive got the fan on it and a zalman fan on the back of the case 2 cm feom the back of the hs and the psu above it so i dont think its an airflow problem. I did however notice that when i applied the thermal gunk to the cpu not much got on the middle of the hs. Have i got a warpped hsf plate or cpu and how can i check ?
