Hive active thermostat receiver wiring
21 Dec 2020
Hello!
A friend of mine just brought me a Hive Active Thermostat (Dual Channel) and I'm trying to figure out how to wire it. I have a Y plan system. There is one 3 port valve that allows to just get hot water without sending hot water to radiators, when I press the hot water button at my current thermostat. There is no option for just central heating with no hot water (and I don't want one).
The current wiring on the old thermostat is like this:
So, as can you see, I don't have a HW OFF or CH OFF wires. They are both bridged to L. Will my existing wiring work with Hive? If so can anyone point out how to wire the Hive receiver? Thank you!
