- 17 Oct 2010
I would guess that the jb is just com and heat on only, no live or neutral, possibly extra low voltage or volt free contact - vokera manual will prob say - put just the brown and blue from the flex in 1 and 3 on receiver back plate
the red and black must go up to the old programmer and can be left in the jb incase its needed in future, this should make the cable up at the programmer dead and safe
You will need to take a live and neutral from the fuse spur to the receiver back plate to power it
Ps. obviously be careful and double check - my guess is based on your 1 post and is best guess only
