Whats the status with Half Life 2 64-bit? I know its out, but how stable is it? Also, on my x64 install of windows, I only installed steam, then copied my copied my steamapps folder over. I'm assuming this means I only have the 32-bit version, since thats what I copied over? If thats the case, would I have to redownload it to get the x64 version, and how would I tell if I'm running it?
Thanks.
Thanks.
