Hmm, cant decide on case now :(
23 Mar 2008
I'm looking for a case to house:
Q6600 with Tuniq tower (I mention this because I've heard people mention some side panel fans get in the way of the tower).
2x 8800 GTS cards.
I won't be water cooling so it needs plenty of airflow which leads me to believe for it to fit all that with good air flow it needs to be a full tower case. However, I cant really spend more than about 130 quid on it.
Edit: May get just the one GTS, not quite sure yet. So many decisions to make!
Ideas?
Cheers
Have a look at the Antec P180/P182. This might not be big enough for what you're after though, or try a Coolermaster RC-1000 Cosmos. They are huge!
I love the look of the Cosmos, I'll look in to that - I wonder if theres room for water cooling within (for the future perhaps).
A Lian Li PC-A10 is within your budget if you look around... Loving mine, great build quality, was so easy to install my old Socket A rig (short term before i finally decide on what new mobo/cpu/ram combo I buy) on the removeable mobo tray.
From the huge pc-a10 thread on here, with pics, I know that Tuniq Towers will fit at least some mobo designs...
