Hmm fiesta worrying me...
Wouldn't worry about it. Your car wont have equal weight over each wheel. When you get in it on the drivers side it will probably be level anyway
suspension might not of 'resettled' after jacking it up. go for a drive and come back , but as si says too, you will have one side of your car mainly supporting the engine and one side the gearbox, the engine is far heavier.
fonzee said:
Yup, i had the front end up whilst checking the disk pads... What can this do?
The car might not be sitting right, drive it forwards about 10ft and put it back should be ok then.
You must have a very good eye for level spotting half an inch! lol
