Hmm... Help need advice..
5 Oct 2014
So I'm stuck between a couple of cases...
This is what I'll be swapping out :
hz4pmaY
https://imgur.com/hz4pmaY
I'm stuck between the
Lian li mesh 2
And the lian li dynamic
Fans ill be using its a mish mash of corsair sp120's as and since generic case fans *for now*
Edit: if anyone has the dynamic, would my res fit in the *back* compartment?
There lots of nice pictures of owners Dynamic cases in this thread
https://forums.overclockers.co.uk/threads/lian-li-pc-011-rig-photos.18871110/
This person has fitted a res bigger then yours so you should be ok
I'm going to find out tomorrow if i can fit a rad at the bottom. I've ordered a TX360 20.5mm thick rad for the bottom. I measured if i moved the vertical bracket up 1 slot i could squeeze the rad in... it will be tight but it should fit just fine. That'll give me a total of 240+360+360 radiator capacity. If it works then i'll look at replacing the top rad for another 360 as well.
Currently looks like this:
I have the O11 dynamic razer edition case and it is amazing! Your AIO should fit and this case has excellent airflow. In my opinion the o11 dynamic is the best looking case in the market and, in terms of looks, completely annihilates the mesh 2. Currently in my setup I have 9x fans in my O11 (the Coolermaster MF120 Halos - £39.95 for a pack of three from OcUK) and have them in a setup where the bottom and side are intake, and then the top is exhaust. It creates the negative airflow to keep the dust out and also keep the rig cool. If you want an amazing looking case that has great airflow then I’d really recommend the O11D. It just looks so nice and the cable management is an absolute dream!
