hmmm - fans/motor/dynamo/electronics question
13 Mar 2011
Bada Bing
when ever i am inside my computer, i always try to avoid moving the fan blades becuase i thought it could damage the mobo sending current through it the wrong way, the idea is this:
a fan is essentially a motor with fan blades on the motor shaft. What i understand about a motor is that when the motor is off, any movement at the shaft end sends current back through the motor - essentially creating a dynamo.
another thing i like to do is when i shut down my machine, watch the fans spin down... AND then i thought:
- the instant the mobo shuts down and stops supplying the fans with power, they still keep spinning due to their momentum - so they must also be sending power back into the mobo :confused::confused:
my question is this:
-is my logic correct?
-and if so, does the mobo have some sort of regulator to stop negative voltage being sent through the board?
-is my wariness of moving the fans when off justified?
(BTW, this is just something that came to me the other night when sitting here, it is not important or urgent, just interesting :) )
Your logic is indeed correct (in a Vulcan voice). Spinning a dead motor in it's normal operating direction (effectively turning it into a dynamo) will actually induce a current in the opposite direction to normal (back EMF if you want to wiki it). The drive circuits incorporate a transistor in the output which is switched off when power is removed from the board. With the transistor switched off no current can flow, and when it's switched on no current can flow in the reverse direction. There's certainly no need to worry about an accidental knock, or even a deliberate flick, no matter which way it spins.
oh! - very good - i didnt know they had the transistor - thanks :)
