Hi
I have Ubynutu/Dapper and have just changed from a CRT to a LCD (Viewsonic VX922).
One initial worry is that the preferences/screen resolution says its running at 75hz when i think it should be 60 - it says "WARNING: Do not set the graphics card in your computer to exceed a resolution of 1280 x 1024@75Hz or the maximum refresh rate of 85Hz at lower resolutions; doing so may result in
permanent damage to your LCD display."
So i seem to be just OK but if i lower the resoltion my freq will be too high and i only have the one option in the dropdwon of 75.
Moving on my very limitied knowledege thinks i may need to reconfiger the x-server? I tried that (though now can't recall where i got the command to do it" but it totally messed things up and i had to copy back my old xorg.conf file to restore things. The reason it messed up was that i did not understand a lot of what it was askng me to input.
I thought maybe i could jst edit xorg.conf manually but there doesn't seem to be anything in it that defines frequency.
Any suggestions?
Many thanks
Diss
Any suggestions?
Many thanks
Diss
