Ho 250 g8 ssd mirror?
Permabanned
30 Dec 2021
Yorkshire
My laptop as a 250gb nvme drive and a 1tb hdd, if I was to buy a 1tb ssd can I make the hdd mirror it?
Laptop HP 250 G8 I3 Gen11
Do you mean actively mirror it while in use or to copy everything from HDD to SSD then replace the HDD with the SSD?
Yer set up like a actively mirror or something that would be k up the full drive say ones a week but without me having to remember to do it myself
That's easy enough to do using Robocopy and Task Scheduler. I have a batch file that runs every night to mirror my data drive to another inside the PC and to my NAS. Let me know if you'd like the details.
So I'm assuming Robocopy can be set to just copy a drive as soon as the program is run? And the batch file just opens the program?
Robocopy is a command line program and needs a lot of parameters to make it work. It is possible to make it copy a whole drive in one go but it can get hung up on system folders like the recycle bin so I have a line in the batch file for each top-level folder. This a sample line from one of my batch files:
c:\windows\syswow64\robocopy e:\videos g:\videos *.* /COPY:dAT /DCOPY:T /FFT /MIR /R:5 /W:5 /MT /NP /LOG:videos.log
Open a command prompt, type in robocopy /help, work through the options and tell me whether I should have /NOCOPY and /J in the above line. ;)
Am going be honest I want something a little more plug and play.
With less problems and a much easier user interface.
I'm now looking at macrium reflect. If you pay to unlock all the features you can set a day and time and it will just clone the drive
