Hoe to check fan is working in PSU ?
31 Oct 2007
Gods County(Allegedly)
Moved from a Haf case to a Nzxt Phantom.
Built it today - Nice - cool and quiet - at the moment at least.
Just come up against one small problem :-
I always look to check that all fans are running correctly after a build and with the Haf never a problem BUT with the Phantom I cannot see the psu fan through the bottom of the case, so cannot tell if running.
Anyone know of a way ok checking psu temps and if fan is actually spinning?
(Did think of changing psu round so that it faced upwards but I'd much prefer for it to pull in cold air.:))
Or a small piece of paper in the place where the airflow would be, if it bends you are good. If not then investigate further.
Thanks to both of you !! - It never fails to amaze how simple the answer really is ; just a problem if your a bit of an idiot :o
