Permabanned
- 1 May 2022
- ㅤ
Not yet, on my PC at the moment. But on here it's superb, maxed out.You using your steam deck? How is it running?
Was also wondering if I could stream it from my PC, to the steam deck in docked mode. I could use a controller that way to play on my TV.
I use Windows on the deck but when I stream I mostly use Parsec, I find it better than Steam remote play.Thanks, would be interesting to hear how it plays. Was also wondering if I could stream it from my PC, to the steam deck in docked mode. I could use a controller that way to play on my TV.
Finally got to it today. Beat him quite easily to be honest. Was level 25 though, so that may have helped. Can't remember the spell names of the top of my head but doing thunder followed by two fire spells took around 20% of his HP, so he did not last long
The bad thing about doing what I did which is exploring and doing loads of side quests before doing many main ones is they become almost **** easy.
Does a Chandler Bing victory dance.
What type of shoes does Voldemort wear?
Horcrocs!
I don't think this has been linked yet.
Read Description - This test is invalid
I'm sorry guys, my mistake led you to believe that denuvo was using more cpu than normal, but thanks to @MrMitnick he warned me that it could be the steam ov...www.youtube.com
Frame pacing still appears to be an issue though? but its a remarkable improvement I think. If I could only be arsed to start over again, sod that.
EMPRESS hasn't removed it, they bypassed it. It's still running in the background.The Denuvo free version runs well then?
Right! My Phanteks had a solid rep too but the only thing mentioned in reviews is the transients which were a bit spiky, and since the RTX 3080 series have high power spikes, I guess certain game scenarios like that on Hogwarts just triggers both at the same time and that's when the PSU trips.@mrk I finally installed the new power supply and yup - no shut offs with hogwarts anymore. Crazy that it was tripping the PSU it was a pretty decent one and should have been sufficient
