2 Dec 2006 at 18:32 #1 porkrind porkrind Permabanned Joined 14 Aug 2006 Posts 1,395 want new bits to upgrade my comp £400 to spend what do I buy ??? system in sig
2 Dec 2006 at 18:52 #2 GazD GazD Associate Joined 28 Mar 2006 Posts 2,172 Location Winsford, Cheshire Is the RAM DDR or DDR2, you could get a E6300 and a DS3 for around £200 if your old RAM was DDR2
2 Dec 2006 at 19:52 #3 porkrind porkrind Permabanned OP Joined 14 Aug 2006 Posts 1,395 current ram is ddr corsair 3200 CAS 2 400Mhz
2 Dec 2006 at 19:57 #4 Zefan Zefan Man of Honour Joined 15 Jan 2006 Posts 32,978 Location Tosche Station You could get the asrock ddr1/2 mobo and a 6600 for about £300, using your existing ram.
2 Dec 2006 at 21:50 #5 porkrind porkrind Permabanned OP Joined 14 Aug 2006 Posts 1,395 any performance penatly for using ddr1 over new ram , I guess there is but IS IT BIG!!! some graphs or summin would be nice as that sounds very intresting whats the board called ? Last edited: 2 Dec 2006
2 Dec 2006 at 23:31 #6 CHUDS CHUDS Permabanned Joined 15 Oct 2006 Posts 567 Location N.Ireland Asrock 775DUAL-VSTA VIA PT880, S775, AGP / PCI-Express, DDR/DDR2 400/533/667, SATA I, SATA RAID, VGA i'm getting for temp, good for half upgrade
3 Dec 2006 at 02:58 #7 humax humax Associate Joined 8 Nov 2003 Posts 2,093 Location england dont bother with any of the above .just give it to me
3 Dec 2006 at 09:52 #8 lee87 lee87 Permabanned Joined 31 Jul 2005 Posts 2,592 porkrind said: any performance penatly for using ddr1 over new ram , I guess there is but IS IT BIG!!! some graphs or summin would be nice as that sounds very intresting Click to expand... There is hardly any performance difference between using DDR1 and DDR2 memory in the games tested here. http://www.anandtech.com/mb/showdoc.aspx?i=2810&p=6
3 Dec 2006 at 17:21 #9 porkrind porkrind Permabanned OP Joined 14 Aug 2006 Posts 1,395 OCUK sell that board then ?
